- Jan 4, 2021
- 2,756
How Do They Do It?
Standard ER32 collet sets are 3mm – 20mm (maximum capacity). Several vendors (I got mine from SHARS) sell 1mm, 1.5mm & 2mm, and I always understood how these could work since they have a smaller clamping range (0.5mm vs. 1mm).
However, I also had 21mm, 22mm, 23mm, 24mm & 25mm ER32 collets that I purchased directly from China on eBay. I figured they got away with these sizes by making the bodies thinner and spec'ing them with a higher TIR (0.0006" vs. 0.0003" for the standard and mini's), but I just received an ER32 26mm collet from Ali (after being pointed to it by @Advil here) and I finally figured out how they get away with making these "impossible" capacity collets:
The 20mm is from my standard set, 21mm through 25mm are from my previous eBay purchase and the 26mm is from Ali. Obviously the larger the capacity the shorter the back end of the collet, and they also play with the number of slots. Mystery Solved!
Once I can do something other than take pictures in the shop I'll do some kind of comparison; don't have any precision ground bars in the 20mm – 26mm range, but I'll figure something out. In the meantime I have to address organization – I don't have room in my Odd-Size ER32 Collets box:
