- Jan 20, 2018
- 5,818
I'm tired of having to buy a new can every time I need some. Has anyone found a method of storage that works? I'm thinking maybe keep the can in a Mason jar, but I'm hoping someone has already found the answer.
Good idea with the foil. Need to make sure there are no creases and it's smooth, but should form a metal to glass seal with the seal pressing it into place. Wasn't sure of the hardening mechanism, if was simply solvent evaporation or not.When I use my PVC/ABS cement, I carefully clean the lip of the neck before closing. This seems to help in preserving the cement. I also started storing in wide mouth Mason jars although I would expect some permeability through the rubber seal on the lids. To counteract that, I put a fresh piece of aluminum foil on the glass, forming it to the glass and trimming it. I last used the cement about two years ago and when I checked it today, it still sloshed in the can. Another solution would be to put a can of the primer in with the cement. The fumes from the primer will increase the concentration in the jar, slowing down evaporation from the cement cans.
I've done this. The only thing it does is allow the glue to solidify right under the cap, making it really difficult to open the can.I read once that inverting the can would help. Never remembered to do that. Last can I bought, I did remember to turn upside down. It's only been upside down about a month though. We'll see.
