Oliver bandsaw
Bondobob
Nov 11, 2022
6
Hi
I am a new member.
I recently purchased a Oliver bandsaw and am looking for any information as to what model and year it is.
Anyone ?
Have you checked over on Vintage Machinery.org?
It's definitely a wood cutting saw.
Looks like Vintage Machinery site is down :(
Yes I think so? Not sure what I have. It was used for aluminum by the last owner
The direct belt drive from motor to drive wheel makes it too fast for any metal besides aluminum. Metal cutting saws have a reduction gearbox or multiple belt reductions to achieve speeds slow enough for ferrous metals.
The direct belt drive from motor to drive wheel makes it too fast for anything besides aluminum. Metal cutting saws have a reduction gearbox or multiple belt reductions to achieve speeds slow enough for ferrous metals.
I plan to use a VFD to control the speed
Looks like a model 17 from the 1920s. If you have a serial #, I can find out the date but likely 1915-1925 range. For metal you will need to gear it down as it probably runs in the 4000-6000 fpm range and the motor won't have much torque at metal cutting speeds. Dave
Thanks for the information!!
I searched out a model 17 and it is listed with 30 inch wheels, ours is 32 inch. The images that I located show OLIVER cast into the base, ours has no markings. Would love to know more about this machine!!!
