Older 10T Hein Werner Air over Hydraulic Press - service
Thanks,
I will give them a try as soon as it defrosts around here. Too cold to be digging in the garage to find the model number etc..... perhaps April it will be warmer!
Regards,
B
I have an OTC dual piston head and pump cylinder 17 1/2 ton on an old 20 ton weaver press and it started leaking ....I disassembled the head and found one
of the O-rings had a nick in it ....pretty cheap fix, got the o-ring at a local ace hardware....is yours actually broken ?
