- Sep 4, 2013
- 113
I've got an old metal shaper, it's an 18" newey engineering, my grandfather bought it at an auction god knows how many years ago, set it up in his shop and used it maybe a couple times. I think he just couldn't figure out how to run it, or if he did, didn't have the right tooling. When I recently dug it out of the back of the barn, it had a little drill press vise bolted to the table, and a lathe tool holder in the clapper. I've mounted a big milling machine vise to it and located the right tool holders, and it now works beautifully. My problem is, I'm not sure of the oiling system for the bull gear. There seems to be no way to oil it, other than taking the side cover off and putting the grease to it. I also don't see provisions to oil the rod that runs the ram. I know this beast has been modified, it has a 220 volt single phase motor, obviously not factory because the mounting plate for it is fabbed and not in the right spot (only 2 of the 3 drive belts line up). Also there is an aluminum plug in the side of the main casting, covering a maybe 2-1/2" hole. I would think there used to be some sort of oiler here for the bull gear? I can't find and info about these on the net or original pictures
