Well, I cleaned it up and it's working. What a difference when machining.
The level tube is leaking at the joint with the brass elbow so I just removed it and plugged it.
Mounted it on a block of wood with a heavy uni-strut ell bracket so that I can move it between the lathes and the mill.
I finally researched the Boelube and it's dilutable (SP?) 20:1, went thru about 40oz of mix doing the brackets.
Judging by the mess on the mill I may have had the flow to high...
I will be needing to modify the tip and or hose so that I can get away from all the fog.
While I was milling the brackets for the springs I had a small fan going blowing the mist outside.
_Dan
