- May 25, 2016
- 181
I could use some pointers - I'm trying to pull apart this old Delta induction motor just to clean it and check the bearings.
I managed to tap the rear bell housing and loosen it (some penetrant helped).
Now I have it loose, and can get a small screwdriver tip in there, but I'm not wanting to pry on it and risk damaging the housing.
The rear bell housing also has a shaft coming through it, so I assume there are bearings pressed on the shaft.
Any tips on pulling motor housings apart safely? I really don't want to hurt the motor. Other than some slightly noisy bearings, it seems to work fine.
-Tom
-Tom
