Derrick,
I'll answer the rest of your PM here. The machine is an early Craftsman 12x36. First, if it has back gears, it is not a 101.07360, which was an 8-speed machine (no back gears). I take it that the nameplate that should have been on the back of the bed was removed by some PO and lost. It could have been bought originally as a 101.07360 and then later the PO bought and added the back gears. Which would have turned it into a 101.07380. You need to acquire a copy of the correct MOLO version as well (see previous post).
I just created and uploaded the basic instructions for adjusting babbit spindle bearings. Includes the headstock section view.
I've been through all of the pertinent Craftsman parts lists and there is no part numbered L6-252 shown. The part with sequence number 252 is 10-252, used up through 101.27440.
Judging by the two-piece change gear cover, the bed legs, early pattern tailstock and the round knob instead of two-handle 10D-308 crank on the compound feed screw, I'll guess that 101.07380 is probably correct. 101.07381 should have the later one piece cover, wider feet, and the crank on the compound. Otherwise, the two models are the same. At a guess, it was made in 1936, one of the earliest Craftsman 12" machines.
Where did you find L6-252 stamped? Generally, the only Atlas parts with part numbers actually on them are cast iron parts, and the number is raised, not stamped. Serial Number of the machine should be stamped on top of the front way near the right end.
I have to go burn burgers now.
Robert D.
