want to service my lathe and give it a spring clean can't find anything in instructions i got with it.
it's a clarke cl 430.
got some odd fittings and dont know what type of oiler i need.
pic 1 is lathe
2 is fitting.
got two sizes of fitting.
If it works $40 is cheap. I've been through numerous oil application devices (I also have a number of different styles of oil fittings on the various machines). The last one I got was about $100 - but it works very well.
There are several build it yourself options. Whatever you do it is important to deliver the correct lubricant into where it is supposed to be.
