- May 6, 2020
- 28
About half a year ago I bought this swiss milling machine. After thorough clean up it looked good and there wasn't a lot of wear in the mill (Scraping marks still visible on some places). I have opened up everything that was reasonably reachable and found some grease in some place that should be lubricated by oil. After getting the old grease out I tried to see if the oil pump would pump oil over the gears in the head/top of the machine and it didn't. When looking through the oil flow window I could not see oil flowing. After experimenting with the oil level (less and more oil in the gear box) and removing the oil winding and pouring oil throught that there has been flow for a little bit, but not for long.
Where do I start with solving a problem like this? If it all possible I would like to have the gears and guts of the machine stay in place.
A secondary, less pressing problem; the oil cups have holes in them and I think there should be wicks in them. Does it matter what kind of wick or rope i put in there? Do you guys think it would be a problem if i just kept topping the oil cups every X hours of use?
