Hey all,
I am rebuilding an Atlas 10" lathe and need some help with the oil points. I am needing to replace some of these as they are damaged or missing.
I have tried different searches. 'oil cups', 'lube points', etc. etc. What am I looking for here? :thinking: Any links to them for sale would be great as well. Also how are they sized? Is the size across the bottom of them?
Also I am seeing that this lathe appears to have been worked on before. This picture is showing the side of the quick change gear box. Most of the holes appear to have been resized to allow for sleeves to be put in. This has blocked all the oil points. Is this ok or do I need to be changing this in some way? Any oil put in these oil points goes no where. Do I need to put a hole into these sleeves so that the oil gets in the joint?
Thanks for any help.
Philip
Philip
