- May 3, 2020
- 346
I'm working on a Gaertner microscope. The X- and Y-axis screws are very fine---0.025 travel/ turn or 40-TPI. There are oilers at either end of the screw that close with a screw cap. Is the oil supposed to run through the bearing onto the threads? There's no obvious provision for getting oil on the nut. The X and Y screws are basically a micrometer which makes me think that the threads are meant to run dry. The nut looks to be bronze and the screw is probably steel.
I dissolved a lot of the crud on the screws with WD40 and a brass brush. Spray, brush, rinse, move nut, repeat, spray, blot with paper towel. I've partially re-assembled. Will the WD40 flash off? If the bearings are meant to run dry, do I need to clean the WD-40 residue off with IPA? Better now, before assembling the bearings.
What kind of oil should I use?
