Was using my Atlas 10100 the other day to face off some bar stock to make a bucking bar for riveting. Set everything up in the 4-jaw as square and centered as the old eyeball would allow (first time setting up square shaped material). Pulled the locking ring to disengage standard drive then flipped the lever for the back gear since I wanted to slow things down for the interrupted cuts on the edges.
Noticed a slight vibration that wasn't there when running in standard drive (laid hand on headstock, felt it shaking a bit). Took light cuts of 0.005 til I got the dimensions I wanted. Strange thing was when I returned the lathe to standard drive (pressed locking collar back in while rotating drive pulley by hand til it engaged the pulley), the vibration remained...??
Soooo....I disengaged the locking collar again, rotated the pulley 180 degrees, then engaged the locking collar again which seemed to bring it back to more of a "hum" as it ran in standard drive. Anyone else ever have this happen ?? Is it just the way the 10100 runs ??is it possible the locking collar acts as a balancer of sorts and can be positioned 180 degrees out ??
Spindle/4-jaw chuck have almost no play when a 1" X 8.75" round bar is setup in the 4-jaw and grabbed & pushed/pulled by hand. Set the dial indicator on the outer edge of the 4-jaw before flexing the bar. The DI needle stayed around 0,0005 in all directions the bar was flexed. So I don't think I have a bearing issue...How smooth is the Atlas 10100 expected to run ?? Thanks.
