I got the new bearings in my mill and found that someone had previously installed the bottom thrust plate upside down, so no matter how much you torqued the nut, you could never take up the end play (the whole reason for the bearing replacement). Anyway, the mill is now very quiet and tight, but
i have a problem that is driving me crazy-the quill is pretty tight at the top of it's travel, but when it gets past about the 1 1/2" mark, it travels just fine. There seems to be plenty of oil on the quill and there are no signs of it dragging that I can see, but it's just freaking tight. I didn't force it either in or out, the gear is loose and not binding, and the return spring is actually not even installed right now because one end was cracked at the eye that goes over the stud, so I just left it out for the moment.
Any ideas other than just wrecking it back apart and coating it in Dykem to see where the problem lies?
