Heres what i use to line up nuts that need welded to an item and the bolt has to line up nice. Its a turned down shaft with the id of the nut on the end with the dia of the hole on the bigger end. Works perfect and i have them from 1/4" to 2"...Bob
That's a pretty sweet first lathe project idea! Thanks! I always just went jurry rig style on it and used the bolt and then didn't tighten all the bolts until they were all threaded once or twice first.
