Now I went and did it. Let the fun begin!
Good luck with the transport. Be safe, the 935 is too heavy. I’m so glad you ditched the 835 idea for the 935.
what's the trailer rated at?
what's the load?
Worried that the axle might not be up to the task.
Can you do one at a time?
It's a double axle 7000# car trailer, weight wise I will be fine. Getting both machines on there at the same time might be a problem. If that's the case, I'm sure it won't be a problem to haul one at a time.
Tim
Both the mill and lathe are in the shop, almost went without a hitch. My tractor was big enough for the lathe but would not even budge the mill. I called the rental place to rent there offroad forklift, he told me he just rented it out for 6 months. But then luck was on my side, He asked how long I needed it? 5 minutes maybe 10 at the most. They had just loaded it up to take it away. He had is driver bring it and move the mill into the shop.
All loaded up and ready to go.
Bringing the mill into the shop.
Uncreated and ready to start cleaning.
you are so lucky the guy had the forethought to ask.
looks like you will be busy for a while cleaning them up.
pics when they are ready to use...
enjoy your new toys.
Congrats on the double haul! You've got some cleaning and setup to keep you busy for a while.
