Tim, congrats on the new machines, they will be worth the wait hang in there. You should be able to find Mark's (mksj) posts and see what you need for the VFD enclosure. His specs should be a closer size for your machine than the actual VFD I purchased. The overall set up is very similar regardless of the machine, Mark helped me size the right components for my build out. As for the control panel, I used what came stock on my lathe. I swapped a couple of items in the holes, and only drilled 1 very small hole for a toggle switch, and made an insert to reduce the size of one hole. If you do need to make a new plate, with your new mill that should be easy work. Let me know if I can help with any VFD questions. Mark is the true expert but if I can take some of his Q&A load off with the easy questions, happy to help.
