- Nov 8, 2012
- 783
Okay, I’ve been wanting to put power feeds on my Clausing 8520 mill. In a vain attempt to save a few $’s, I ordered the PF from CDCO, but was unable to make it work. From others, I know a Servo type 140 PF will work. However, with a prive tag between $600 and $1000 each plus mounting kits turns into a bit of sticker shock.
Eventually I’d like to get into CNC, but think I’d rather go with something like a Tormach or Precision Matthews when I do. So what I’m contemplating is getting a 3 axis CNC conversion kit to use stepper motors instead of PF’s and set it up to control them manually. Looking at going with an Arduino control system mostly due to wanting to use Arduino for other applications.
Unless it becomes necessary to add ball screws, I’m planning on sticking with the original acme screws. According to Jim Dawson (http://www.hobby-machinist.com/showthread.php/28282-Servo-Motor-sizing), NEMA 34 steppers in the 1200 oz-in range should work though he stated I’d need to gear them if sticking to the acme screws. I’d rather just direct drive instead of messing around trying to gear or belt drive them.
I haven’t completely ruled out the possibility of doing a full CNC conversion, another reason I’m considering stepper motor drives over power feeds.
I’ve been looking at Automation Technologies (http://www.automationtechnologiesinc.com/) though I haven’t shopped around too much yet. Most of theirs seem to be closed loop hybrid steppers. For my purposes, I don’t think I need that style, but I could see the advantage in a full blown CNC conversion. From my very limited knowledge of CNC, closed loop would mean no missed/partial steps.
So beyond the Arduino control portion, what else would I need besides the stepper motors, power supply, and drivers ?
Would 1200 oz-in steppers work with a direct drive set-up using the acme screws or would I be better off changing over to ball screws or bigger motors ?
