I have a Select 816b lathe that has what appears to be a Norton style gear box. I have trouble with the 2 tumblers falling out of the holes when running at the faster feed speeds. No problem on the slower ones. The left one is more problematic, again, at higher speeds. The longitudinal feed and threading are both operated with the half nuts on this lathe.
I do note, as you will see in the photos, that the pin that goes into the gearbox hole is pointed and bent on the left one, while the right one is cylindrical and straight. Also noteworthy is that the left one has apparently been brazed (see photos # 3, 4 and 5)).
I did try to take off the pin of the left one to fabricate another; but, it looks like the pin may need to be drilled out of the handle. Didn't want to do that since that may not be the problem. also, you can see that it appears that a previous owner attempted to hold the pin in, maybe with vise grips, as can be seen in the damage to the top of the left tumbler in photos # 2 and 3.
I guess what I am trying to find out is the root of the problem that makes the lever so jumpy (bouncy) and prone to pop out at the higher feed rates. Please help me get this figured out.
