- Dec 1, 2014
- 56
I recently purchased a boring bar and was curious if I can use just any insert of the same diamond shape in it or does it absolutely need to be a very specific type of insert to fit in it?
The boring bar I got is a Kennametal E06-SDUPR2 NJO The boring bar has a through hole for coolant and was described as a carbide bar. It came with a box of 10 inserts Walter Valenite DPMT 070204-2A US10. I researched a bit and found that these inserts are pretty much worthless to me since they are for cast iron and I have zero plans to work with any cast iron.
The question I have really is about the inserts. I want to be able to use this boring bar on stainless steel and cheap mystery metals. I was given a bunch of weight lifting bars from work for free (they were sitting behind the shop for what looks like years and the guys heard I wanted any scrap metal I could find to play with on my lathe so I got them all for free). I am curious after reading on the forums here what exactly letters and numbers I need to use to order inserts for the bar properly to work on steel and SS?
Any assistance would be much appreciated. Oh, I will try and upload a pic of the bar and box of inserts it came with in case it might help (there was a different insert in the bar than what is in the box of inserts so I have no idea what the gold colored insert is or what it's for).
Curt
Curt
