- Apr 12, 2013
- 562
Just curious as to what volume I should expect my lathe to generate when running at max speed.
Background: After finishing my spider and replacing the preload collar with the spider, I tightened the prescribed 2 teeth of rotation. I found a deal on a Harbor Freight non contact IR temperature 'gun' and over the weekend ran my lathe in to see about the bearing temperature rise. I have always avoided max RPM operation because A) Never needed it, and B) Don't like running at the extremes of any machinery.
The noise level was quite non-hearing safe. I work in refineries, we take safety classes like most people take meals, and they preach 'if you gotta raise your voice to talk around machinery, it's not hearing safe'! No doubt, this lathe is not hearing safe at 3 paces away running at max (2072) RPM. One notch lower (1270 RPM) is marginal.
My experience with bearings is noise==wear/damage, but my experience is mostly automotive bearings. This lathe has not been babied by any stretch, especially by the original owner that my Grandfather bought it from.
How loud is acceptable? BTW, max T was just over 120F from an ambient T of about 85F.
