No Low Back Gear On 2j Variable, New To Me
genevamotorsports
Nov 29, 2014
13
I just hooked up my new-to-me Bridgeport with the 2J variable speed head . Everything on the unit is tight and works except when shifted into low back gear, it seems to run in "neutral". The lever detent is solid. Is this a common problem? What should I look for when tearing into it?
Are you sure you are all the way into back gear ? There is a center detent for Neutral. Sometimes I need to jiggle the spindle a little in order for the gears to change all the way.
Yes, the lever is securely in the low detent. Thanks for the input. I'll have to open her up and find out.
I found the problem. Back gear doesn't work without a timing belt! Obviously the previous owner wasn't using low gear... I had no way to check it under power but it was in such good shape vs the price, I took the risk. I'll put two new belts on while it's open. All the rest is good.
