- Mar 26, 2018
- 8,664
Hello,
I joined this forum because it looks much friendlier than that other site with all the experts.
I have a 77 tear old South Bend 13" single gear box and a 1970 Bridgeport milling machine. Both are in pretty good shape for my needs.
I am working on an old Marvel 612 Horizontal band saw. The pic is of the lead screw for the vise. As you can see it needs to be replaced. I found some threaded left hand 3/4 10 TPI rod that I'll make work The nut will need to be made. I am fairly confident I can do it. I need to buy a left hand tap for the screw threads.
The saw was really rough when I bought it. I removed all the krud and took it down to inspect and clean. The cast iron frame and components are in great shape. I replaced the blade guide bearings, the gear box has 80 wt gear oil and is in pristine condition. The last thing to do is this clamping device.
Wish me luck, I may need some help along the way.
