- Jul 25, 2013
- 45
Hi Folks,
I am back from long overdue holidays and catching up with work.
After more soul searching, I am coming to the conclusion that the Taig machines will offer me the best value for money for small hobby work, and offer a slight advantage in size over Sherline. Wabeco sure look nice but the cost would leave no room for tooling. I have not spent much time looking at Sieg, but there are more negative reviews on those; maybe because more of them sell?
I’ve been looking on various forums and the consensus (last year) was as follows on differences between Sherline and Taig;
“Sherline mill Pros: variable speed motor, better class thread on the headstock for screw on accessories, hardened spindle nose for accuracy with MT1 spindle mount accessories, lots of accessories available, easy to upgrade to CNC with excellent bolt on motor mounts”, and for “Taig Mill Cons: Motor, headstock not hardened except ER16 versions, the CNC motor mounts
leave a LOT to be desired, fewer accessories”.
“Some people like a mix of a Sherline motor on a Taig Headstock with a Taig mill or even an entire Sherline motor and headstock on a Taig mill.”
“If you are on the lookout for a lathe for precision work, do not put the Taig lathe on your list, it has many more issues than the Taig mill. For precision consider Sherline, Cowells, Levin”
“I have a Taig mill CNCed and a Sherline 4400 lathe CNCed…I didn't go with the Taig lathe because I didn't like the approach and it is more difficult to CNC.”
“If I were starting over, I'd get a Taig CNC ready mill without the AC motor and add the sherline motor to it. Having used it on my lathe, its fantastic. I can control the speeds via mach3 as well as get index feedback. With the Taig motor I'm consistently changing pulleys.”
“For the electronics on the Taig I use a STDR-4C from Soigeneris. It is a well packaged setup with a g540 in it. His 166 oz/in motors work great on the taig.”
“I do use a sherline rotary table for a 4th axis on my taig and it works well. In fact, I find myself taking the chuck off the lathe and moving it to the mill (or vice-versa) to do complex operations.”
Q1. What do we all think of these comments please?
This is the feedback I received from my potential supplier:
"The Taig mills – whether manual or CNC – use the ER16 headstock, which Is rated at 10,000 rpm and has the 22 x 1.5 mm spindle thread. Most Taig mill accessories are designed to be mounted in a 10 mm or 3/8 inch ER16 collet. Some of the comments below are no longer relevant as the ER16 headstock is superior to the Sherline equivalent and the Taig accessory range has been expanded. I would agree that the 6-step pulley system for the spindle motor is antiquated even if it is adequate. The yet-to-be-released CNC lathe has a variable speed motor that will be controlled by the Mach3 software, completely eliminating the 6-step pulley system. I have been informed that this new innovation will transplant to the CNC mills. At this stage, the launch of the CNC Lathe is 9 to 12 months away."
"The rotary table that is supplied as the 4[SUP]th[/SUP] axis in the Taig CNC Mill 4000 is an adapted Sherline model. It is controlled by the Taig specific Mach3 software without issue."
"I would definitely recommend the Taig CNC Mill 4000 over the Sherline equivalent as it is a far more robust machine, and I would wait for the expected release of the Taig CNC Lathe early next year, in order to compare with the Sherline CNC Lathe."
Q2. Do these comments sound fair?
Cheers, Colin
Cheers, Colin
