- Jun 19, 2017
- 83
Hi there,
I just bought a Hitorque 5500 bench mill and all the trimmings from LMS.
This is my 1st machine and other than reading forum posts, I wasn't sure what I was getting myself into...
Anyway, I wiped it down, installed the power feed kit, slapped the vice on it, and put a piece in and started cutting. Just wanted to cut something. Anything.
Man am I glad I got the power feed. The spring on the hand wheel is annoyingly strong and cranking that thing would get old fast... The power feed has one drawback. If I try to run it very slow, it doesn't rotate smooth. The work piece is fed in little "spurts", like it either doesn't have enough torque or there's a hard spot somewhere in the rotation.
When I speed it up, it works just fine.
Then, I noticed there seemed to be "steps" at every row that my end mill went down. After I finished I removed everything and cleaned up and got out my tramming rig.
I set it up so that it would sweep the table all the way across from front to back. (about a 5 or 6" circle?)
It seems to be out in 2 directions. Like the table is low in the back and low on the left. (about .003")
I ran the table all the way left and right it the indicator doesn't seem to move at all.
So, my question is, if I decide to start shimming the column, can I loosen it without removing the tapered dowel pins? Like if I loosen the bolts, can I tap on the side at the top to create a space on the bottom for a shim?
thx,
Jim
thx,
Jim
