- May 13, 2019
- 1,016
Hi all,
I'm a newbie when it comes to machining and I need a little help.
I have a MicroMark MicroLux 7x16 mini-lathe. I've been trying to machining some brass (C360) on it and I'm getting what I would call "catches" or "grabs" when I'm turning. The work seems to catch and either leave a deeper than wanted gouge or the work jams and the motor stalls. I'm looking for why this is happening. It happens on face turning and length-wise with a slow feed rate.
I'm taking very light cuts (0.003" - 0.005") and the RPMs are low (not sure the exact amount). Everything seems tight on the lathe. All gibs are tight without play as far as I can tell. I'm using HSS bits that I'm sharpening myself on a high-speed grinder. I'm fairly certain that the bit is very close to the center line of the work.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
