- Jul 8, 2015
- 26
A couple of years ago I was lucky enough to walk into a shop at the right moment after a terrible accident.
I stared at the carnage and knew the lathe had been used by a former employee a lot, but there was nobody left there that could operate it, and it seems that we just replace parts anymore and not really "fix" things. They were moving it out of the shop to "storage" and making more room.
Being the opportunist that I am, I jokingly asked if anyone had dibs on it. The manager stated that "It's scrap now, if you want it, get it out of here now."
"Can I borrow your fork lift please?" And I moved it right out of their way for them.
I picked up the pieces that separated, and stashed it out of the way until I could get my trailer to haul it off.
I retired in December and now have some time to get back and start re-learning machine shop from long ago. I took Machine shop in High School, and one class in college, but after looking for parts and researching lathes, a few things have changed in the last 38+ years.
I've cleaned it up, replaced the belt, fixed and welded the cracks in the belt cover, made new hinges and a pin for the belt cover, and played a little on it with polishing some things, and facing off some aluminum. Traced out the numbers and it's a 1947 model 820.
BUT.....
In the fall, it landed on the three jaw chuck and bent the spindle about .006".
I've researched it and found that need a part # LA-660 which is now a LP-1303.
QUESTION;
Will a Model 200 spindle work in this 820 headstock? Or what spindle will interchange with a 820?
It now sits in my garage awaiting the transplant from a donor.
Any help would be greatly appreciated!
BUT.....
QUESTION;
