I have access to a Enco milling machine. The machine however does not appear to be set up properly. Specifically when you are standing at the machine, the head/spindle is off to the right. The machine has a round column, but there are no wheels to move the head left or right. You can grab the head and move it right or left.
What is it called (the process? squaring???) to ensure the head points directly forward and not to the left or right? The machine appears to have 2 bolts near the rear that can be tightened to hold it in place, but how can I go about ensuring I set it at center before I tighten??
Any help would be great!
Thanks
Thanks
