New Wrench from Old; RF30 Spanner
RJSakowski
H-M Supporter - Gold Member
Feb 1, 2015
10,119
I just finished a big project where I used my old RF30 clone for the much of the machining. It seemed to me that there was some unwanted vibration although the TIR is on the order of a tenth and I could not detect any deflection of the spindle . I decided that it was a good time to pull apart the spindle and do a visual check on the bearings as well as to confirm the bearing numbers in the event that I might want/need to replace or upgrade to AC bearings.
As anyone who has serviced an RF30 or one of its clones, the spindle bearings are preloaded via two nuts which require a hook spanner wrench to loosen or tighten. The usual way is to use a drift and hammer for this task for want of a proper spanner. This didn't appeal to my sensibilities so I decided to make one today. I thought about cutting one out of mild steel plate on the Tormach CNC but decided that I really wanted a carbon steel.
When I bought my Tormach mill 13 years ago, I also bought the TTS tooling system which included six collet chucks. As it turned out, they also sent six sets of collet wrenches so I had five spare sets. I had repurposed two of the wrenches, one for the QCTP nut on my lathe and another for the nut for my lathe spindle stop but I still had four sets hanging on the wall. With a simple sketch, it looked like I could repurpose one of the wrenches for my new spanner.
The wrench was file hard to start so my first step was to heat the business end to a dark red which should remove any hardness. I then sketched my wr3nch design on the old wrench with a carbide scribe and cut away most of the steel that wasn't a spanner with my hack saw and bench grinder. I removed the remaining unwanted material with various files and touched up the outside with the bench grinder and checked the fit and function on the spindle nut. Satisfied with that, I heated to a bright orange, tested with a magnet and quenched in oil. After brightening the surface, I heated the wrench to a bronze color and quenched.
Using the proper tool for a job is doubly satisfying when you have made the tool. Here is the before and after.RF30 Spanner .JPG
