- Jul 11, 2020
- 24
Greetings all. Yesterday I came home with a vintage "Vico" Vital Corporation lathe. I've been using a ROMI 13-5 at my pal's engine machine shop almost every weekend for the past 6 years and I'm quite used to it. This new to me Vico is quite different. I can find no information on it but was told (on a site I definitely didn't belong) that it was a "standard bench top Taiwanese lathe". No search results for JK-350, Vital etc. return information. I have a manual for a Jet lathe that has similar controls, but it's still not quite the same. There are knobs on mine that don't match what I see in that manual. It's currently at my friend's shop while I clean it up and make a space for it in the garage. I'm afraid I'm going to have hundreds of questions for you folks here in regard to running the lathe (do I really manually move the belt to different beltways for different speeds) cleaning (the gears are covered with heavy grease. How do I get them cleaned/lubricated efficiently/effectively) and usage of the controls (cross feed doesn't seem to work; hope it's not serious).
This thing was surprisingly heavy. I don't have measurements yet but can add them today. I'm guessing it weighs 450-500 pounds. The two of us could barely budge it. Had to use an engine hoist to get it out of the truck once home. I disassembled the chuck and cleaned out the chips/dried grease and reassembled it. MUCH smoother now. Probably everything needs a good cleaning. It's been repainted at least twice before that I can tell. Once yellow, now blue and may have been a grey underneath.
If anyone has or can direct me to a manual for lathes with similar controls I'd be grateful. I'll add the info on the manual I do have and note the obvious differences. I'll also add more detailed photos as I get them later today.
Would love to hear thoughts on this item and can't wait to start using my "own" lathe.
