- Jun 13, 2023
- 9
Hello all. I just purchased an Atlas 618 Lathe. I'm new to all of this so I need a bit of help. It's missing a couple of things mainly a chuck(4 jaw would be nice to find) and a switch for the motor to start with. Where would I find these and how do I know what fits it? It has Timken bearings. I read somewhere on here that makes a difference on the shaft size. It has one tool mount but zero cutting blades. It looks to be in great shape. Gears are good, no play in the bearings, bed looks good. everything seems nice and tight. I do need a belt to go from the motor to the other apparatus that has the handle on it to engage the head unit. I just would like to get the basics so I can see it run and then get some stuff to actually use it. I see at The Little Machine Shop they sell a kit with a quick change post, bits, cutter etc. I thought I should probably pick that up assuming it's worth grabbing to start with? Please help a new guy that knows very little about these. Only lathe I've ever run is a brake lathe and that was a long time ago, but I'm eager to learn.
