I just picked up Compact 5 and am converting from manual to cnc. Craftsman, I believe, due to the all grey color and lack of emco badging. I picked up a original emco cnc cross slide, cnc cross slide ball screw and nut, cnc longitudinal ball screw and ball nut, cnc motor brackets, cnc belts, and two Keling nema 23 270 oz.in. 2.8a dual shaft steppers. I could not find two mxl 16t 050 pulleys , 1 source that had only one 11mm left, in the US. I have four 11mm coming from China, a Christmas present i guess, unless i find another US source.
I plan on using another 4 axis control to start. But, don't think i'm going to enjoy re configuring drives between a lathe and mill.
I'm sure it will have its own control in short order.
I needed to mod the chip pan to accommodate the bearing bracket for long screw and also notch out the factory iron at rear bearing housing.
Other than settling on tool holding, i hope to have this figured out soon.
There are a few nicks on ways that i need to address with a stone. For less than $1k net all in for a C5 cnc, i'm a happy guy.
If anyone has recommendations for OXA or other tool holding, i'd love to hear.
