New To Me - 10 Inch Model Th42
plus1hdcp
May 8, 2015
34
As the title says, I am the new owner of a 10 inch TH42 lathe. Nothing too fancy but will fit well into my shop and I am happy to be picking it up this week. While the lathe is partially disassembled for transport, I would like to give it a good cleaning and lube as it is set up. Does anyone have a PDF of the operation manual of this model to share?
Thanks
The manuals and parts break down are in the downloads section of this forum. And pictures of it are a must when you get it home. We love tool porn here.
Couldn't see any documents in the download section but learned I am not at the minimum required post count to access these files.
I got the lathe home today and began the process of cleaning / lubing / assembly. I have not yet hooked up the motor as I want to work on the wiring, adding a grounding plug. There were a lot of tooling included. Some highlights are a 4 jaw chuck (no 3 jaw) / many centers including live centers / boxes of reamers and drills / boxes of HSS tooling and other boxes which I have not yet went through. The original cast iron stand legs were included as well as the Atlas quick change gear box. I hope to add a couple of pictures next.
Here is a picture of the lathe and I will take a better picture tomorrow as progress continues on the reassembly. Sorry but it looks like the picture is upside down
And some of the tooling, again better pictures to follow after I sort throughIMG_0283.JPG IMG_0284.JPG IMG_0285.JPG them
Looks like o good amount of tooling. Did you get the change gears with it?
Came with quick change gear box. It will take me a while to get through all of the included tooling. I found it odd that there were 5 brand new, in the cardboard box, .374 reamers. There must have been a good deal on them.
plus,
The QCGB os a Model or Number 1500. The installation instructions and parts list are in Downloads. To have access to Downloads, you need to have written 30 or more valid posts and be reclassified as an Active Member. If you get to the point where you need the manual before you go over 30, send me a PM with your email address and I will send it to you direct.
plus,
I appreciate the information. As of now, I am no where near being able to utilize the functions of the QCGB except for controlling the speed of the lead screw for automatic feeding. I hope to pass the 30 post count before that information will be of use for me but I will let you know if it is needed sooner.
