- May 8, 2018
- 336
Evening all. Machining newb here. I've worked in the auto body industry for 37 years so have done sheet metal work, fabrication and finishing. I have a pretty well equipped woodworking shop at home. I also have a Hobart mig, cold cut saw and some assorted metal fabricating tools, welding table etc.. in my home shop so I'm familiar with just about every phase of making stuff other than machining of which I know virtually zero.
I have wanted a mini lathe for a long time. I've often been in one project or another where I've thought to myself, I could make this or that if I only had a metal lathe so I used my new gun room project for an excuse to get a Grizzly G8688. I shoot NRA F Class. I've been researching, reading and watching vids which is how I found this place. What an amazing resource you guys have here. I must admit that I'm a bit overwhelmed by the machines and the projects and such that I've seen here. I've been accumulating some tooling. I have HSS blanks and a some carbide holders and inserts, a wedge style AXA quick change tool post and assorted holders, a tail stock chuck and cam lock kit from LMS. I have an assortment of measuring tools. I haven't made any chips yet but have assorted aluminum and Delrin round stock. So far all I've done is use the lathe to spin my case trimmers. I'm anxious to make some chips. I'm going to be attempting to grind profiles on some HSS blanks this weekend using the thread here as a guide of course.
I modded a 4 drawer roll cart from Harbor Freight to mount the lathe and house the associated tooling and such. I cut some melamine and edge banded it for the top surface. I used carriage bolts to bolt the melamine thru the existing lid and base to make a solid surface for the lathe.
The lathe setup in it's new home...
The gun room has 2 Harbor Freight storage benches that I've modified along a reloading bench that I built in my wood shop.
Anyway, so much for the introduction. I'll have a bunch of questions once I get to making some chips. Again, love what you guys have going on here!
Terry
Terry
