- Feb 7, 2013
- 792
A friend of mine told me I needed a QCTP for my lathe I was raised on the old lantern post and did not want to part with it but he said the I would like one. After looking at the price of a cheap one and a better one I did not think I would like it that much. After some reading I thought I could build one. There are many designs this is one I came up with I started with a 2" x 2" block of CR I bored it for a 1 5/16 brass plug about 1 1/2 long dont expect exact dimensions I just make up this stuff as I go!
I then bored a 3/4 hole through the center after machining a bras plug to fit inside the 1 5/16 bore. This will be for the cam to move it in and out.
- - - Updated - - -
I then setup and started to mill for the dovetail.
- - - Updated - - -
Here i am milling for the dovetails I like milling dovetails in aluminum, brass and even good cast iron but not steel it is very hard on a small machine even with light cuts.
- - - Updated - - -
Just about finised here made it through without destroying the mill or the cutter.
- - - Updated - - -
I chucked up a piece of stress proof and machined an excentric for the ram.
- - - Updated - - -
I then bored a hole through it for the hold down bolt.
- - - Updated - - -
I then knurled a couple of 1/8 pins out of drill rod.
- - - Updated - - -
Here it is with the cam installed it pulls the brass ram in and out very nicely. I then drill a couple holes in the back side of the block into the brass plug this stops the plug from ever rotating even a little the cam stops it but this insures it.
- - - Updated - - -
In order for the center bolt to tighten down without locking the QC handle I had to machine a little hat for it I will show later how this works.
- - - Updated - - -
I then machined the handle for the tool post.
- - - Updated - - -
After some gun blue I got the tool post done I know what your thinking why did I make a piston type?? well its really not the cam pulls the dovetail back locking it firm against the body. It only takes a very small movement to lock it down and it always pulls it straight and consistant. But I am not done.
- - - Updated - - -
- - - Updated - - -
Now I start the long task of milling a block to start making the tool holders I should be able to get 5 out of this block. Why five? because I did not have enough material for six.
- - - Updated - - -
This was very hard on a small machine I will do it different next time I will probably remove most of the material with a woodruf key cutter then finish with a dovetail.
