New step jaws and customer parts
GT-6 Racer
H-M Supporter - Gold Member
Jun 7, 2019
478
Needed a good way to hold 12”x1”x1.875” polypropylene for customer parts. Through drilled and pocketed near the ends so standard 6” step jaws would not provide enough support. So, new jaws were in order. I had a stick of 2x1 1018 steel. Used the TRAK mill to face and square 10” long pieces and pocket out the bolt holes. Surface ground flat and square matched together. milled the steps in place under clamping force. Then started in on the plastic parts. 79 parts all done. Made a big mess.
Yes, but it vacuums up sooooo easily!
GsT
Yep and doesn’t stab into you either. I cleaned all the oil off the mill before doing the plastic to attempt to keep it from sticking. We will see how it vacuums up in the morning.
