Just got my rotary converter going. Got a control box from Wny off of Ebay. Had a old 5hp motor that weighs about 100lbs. Control box works ok but quality lacks a little. Here is some of my readings. No load A-C 239v ,A-B 238v , B-C 252v A 4.46 amp, B 8 amp, C 7.41 amp. With the 3hp motor turned on and no load on the mill here are my readings. A-C 240v, A-B 225, B-C 230v with A 12 amp, B7.45amp, C 14.21 amp. Do those readings seem reasonable, or do I need to do some tweaking?
- - - Updated - - -
I have heard complaints about the noise a converter makes but I changed the bearings in mine because it set outside for years and my fan makes more noise. You could prepare to leave the shop and not realize it is on.
- - - Updated - - -
