- Oct 12, 2023
- 139
The lathe arrived a couple days ago, and just got it wired up this afternoon. Now I have what I believe to be an electrical issue. I had a trustworthy electrician friend on mine help me with changing out the receptacle and wiring the plug end. Everything is rated for 20 amps to include the breaker. The chuck won’t spin when turning the speed control. It will spin when I hit the jog button. But it has a high pitched “whine” while spinning.
It was originally purchased as the 1440-BV, but was fulfilled with the newer version 1440-2V. From what I can tell there are some cosmetic changes to the control panel, but I’m hoping the electrical components are close enough that some of the more knowledgeable people on here can help me out. The manual leaves a lot to be desired, but I’m assuming that will change when they’ve had some time to update it.
Main panel lights. According to the manual the white light is the indicator light.
The VFD is blinking the “21.40” repeatedly. There is nothing in the manual on how to deal with this. I’m hoping it just needs some sort of a reset.
Electrical box. Looks like a relay that has a red light on steady. I’m assuming there’s an error with that one.
I wasn’t watching when he finished wiring it up so I’m not sure in the main power switch was on when he plugged it in. But I don’t believe it was.
Any ideas??
Any ideas??
