Went and checked it out. They had it hooked up so I got to see it under power. It is very old. It is NO.2 cast in the side, but I could not read the serial numbers to many coats of paint. I have searched goggle for a pic but can not find one. The motor is mounted high on the back of the machine with 3 belts going down to an input shaft/ fly wheel on the back of the frame. Could not get the quill to feed under power ( maybe it does not) The table and knee moved under power. Overall I would say fair to good condition really needs cleaned. I mentioned the weight, an older gentleman said 2k I laughed he said they would weigh it. It is a resale company they have over head cranes and scales. 4054 LBS. Ray C whens the grand prize.
Now the questions what taper is the quill can I find tooling. Does anyone have a pdf manual. The couple I have found online are not the correct one. The head is fixed or part of the casting and the motor is mounted on top and drive belts to an input shaft or fly wheel on the back of the casting.
Thanks
