Hi there
I recently purchased a used Central Machine 7x10 lathe. I did some basic research before making the purchase, but it was not 100% in depth so now I come to you with a few questions.
First, I need some assistance with gearing. This lathe did not come with any extra gearing so I can adjust for threading. Are all the gears in there I just need to reconfigure them? As is, I am not able to use the power feed in general turning purposes because it moves too quickly. If I am missing gears can I buy the metal gear replacement kit from LMS as a replacement and prevention of trashing the plastic gears?
Next, I had to replace the cross slide screw and nut as the brass one stripped and trashed the screw. I have done multiple adjustments but still have about .001 of play. I also have about the same amount of play in the cross slide and cannot get rid of it after adjusting gibs either.
Thanks for all the help. This forum has been a lot of help so far. I tried to include pics of my first completed project too
