- Aug 15, 2017
- 11
Hey Guys,
My name is Chris and i recently bought this 13" South Bend off of Craigslist. I'm new to machining and i'm looking forward to learning a lot here. The lathe will help me with my hot rod and antique car projects. As well as different pieces of tooling for metal shaping.
A friend of mine came over and showed me how to run it a little bit. It seems to work pretty well but i do have some questions.
1. Can someone decode the serial number, 10152TKX14? The catalog number isn't stamped into the gear box tag which i find kind of strange.
2. I've looked at a bunch of pictures of other 13" SB's and they all seem to have a 4 step cone pulley. Mine is only 3. I'm wondering if someone swapped parts on it at some point?
3. For tooling, should i stick to regular HSS or try carbide? I'm tempted to try grinding my own out of HSS.
Here's some stuff that I've done to it since I've had it... I bought a new leather belt from Hudson Belting in Worcester MA. Replaced the two old V-belts that where all stretched and cracked. I got a Phase II quick change tool post (wedge style). I also bought the proper SB lathe oils off eBay and cleaned and re-oiled the lathe. I picked up a trav-a-dial off of eBay to mount to the carriage as well.
Thanks in advance for any info,
-Chris
-Chris
