New drill press
Blackhawk
Oct 20, 2012
255
Anyone know the history of this drill press?
Interesting motor mounting! Either they couldn't get the motor to run in reverse, or they were in a small shop and trying to save room behind the drill press. Good bit of quality kit you got there, good luck with it!
Phil
Hi,
Nice drill press.
I did a quick search and came up with this pdf. Try this web address:
http://vintagemachinery.org/pubs/1141/1706.pdf
It looks close. Your picture shows a serial number and not the model number so it may not be exactly what you need.
Might be the Homecraft. Take a look at this publication:
http://vintagemachinery.org/pubs/1141/1891.pdf
Vintage Machinery has a lot of publications which you can download and print.
Their home page is:
http://vintagemachinery.org/home.aspx
Free to join but, I forget if you have to wait for approval by email. I have joined a lot of sites (powder coating, welding, machning) and some are like that.
Good luck with it.
Shoebox Paul
Looks like a keeper. I thought I'd fix your pic also. And, I like the Deere!
Where is the table? Likely gone to the Island of Lost Drill Press Tables!!:)
What's up with that? You would think that somewhere, there'd be a surplus of drill press tables, but it seems that they're like socks in the drier, they disappear to never be seen again...
There is a great beast in the depths of Hades that eats DP tables. It prefers the good cast iron ones, and spits out the 'cheap' aluminum ones. :panic:
