Hi Everyone - I'm new to this forum. I'm launching a new open-source, DIY project for building a light-weight CNC milling machine that I designed. It's a desktop machine using 14ga folded sheet metal linear slides with double-row guide bearings. It uses a compact router for a spindle. It's not a hugely stiff machine, but with the high speed spindle, the cutting loads are low, and it is pretty accurate. I've been using it for luthier applications (carving guitar necks, bridges, fret slots, inlays, etc.), which it works well for. I've also been volunteering as a high school mentor for the FRC robotics competition and have been cutting a lot of aluminum - mostly 1/8th" plate. The kids find it pretty easy to use.
There are complete plans, instructions, vendor lists, etc. at lobocnc.com. Currently, I'm reselling the set of sheet metal components at cost (made by a local shop), but there are also DXF and PDF drawings of all the sheet metal parts for anyone with access to a sheet metal shop. It's designed for NEMA 17 stepper motors - you can use any standard driver setup, but I've also got a custom driver board I designed. I've got my own G-code interpreter that I wrote, along with a handful of other apps - all of which can be downloaded (with source code) at no cost.
I'd love to get your feedback on this machine (and on the project in general), and hopefully start a user community. See www.lobocnc.com, and let me know what you think.
-Jeff
-Jeff
