- May 30, 2011
- 5
I just started using an Emco Maximat V10 that I have and I am impressed with how well this small lathe works. I just finished making a lower unit prop shaft for an outboard motor and when I did this I had to cut some threads. At this point I realized that it has no thread dial. I managed to get the job done by not disengaging the feed (and using reverse to return).
Going forward, I want to make a thread dial for it. If anyone has done this, can you tell me how many teeth the gear needs to have, i've seen others with 16 or 32. and any other details that I may need to know about this. I will only be cutting American pitch threads due to the current gear set in the machine.
Thanks in advance for any advise. Josh
