- Sep 28, 2013
- 4,394
hmm, not sure this is the right sub-forum, but here goes I've been having problems with runout/ wobble on my ancient mini-lathe (http://www.hobby-machinist.com/showthread.php?t=19650) where a piece of rod would swing in a circle instead of rotate around its axis. I thought I'd diagnosed and fixed the problem with help from the homeshopmachinist guys as a damaged chuck register from someone using vice grips on the spindle. Unfortunately, after some heavy use the spindle is either bent or the headstock (the bearing surface) is worn, with daylight visible between the back of the register and the headstock on the toolpost side, but not the motor side. It also drinks oil - pretty much as soon as I put oil on the wicks at the top, it runs out the bottom, even though the spindle preload is just right.
So, I've been doing some thinking, head scratching and reading, and in my mind the best fix would be to make a new spindle, this time with proper bearings (angular contact or taper roller at the chuck end, not sure about the other end). However, this would entail boring out the head stock to fit the new bearings. I'm not especially precious about this lathe, it's a tool and as it stands, not an especially accurate one. I also have the help of the machinist at work who'd be happy to give me a hand and has some big machinery and decent measuring tools to hand.
However, before I even get that far, I'm hitting issues finding appropriate bearings. The problem is the width of the headstock. Here are the dimensions:
headstock
width (widest point) 1.4in/35mm
width (chuck register) 1.1in/ 28mm
depth 1.3in/ 33mm
spindle
length from face of chuck register to end of preload nut 5.8in/ 150mm
diameter at chuck register 1.1in/ 28mm
diameter at pulley mounting point 0.7in/ 17.5mm
spindle thread is 3/4in 16tpi
The largest ID bearing I can fit would be a 7002 with a 15mm ID/ 32mm OD, but that leaves just 1.5mm either side in the headstock give or take. 7001 would be 12mm/ 28mm which I'd be happier with, but then the spindle diameter would be even smaller which is the opposite direction I want to go in. I'm starting to think that I may be better off thinking about making a new headstock from scratch, even though this would be more money and work, just so I can fit a more suitable bearing, like a double row angular contact or even a taper roller bearing if I can find one small enough.
What do you all think? Any other ideas that I've probably missed?
If/ when I do end up making a new spindle, I was thinking about using 4140PH/HT for the spindle and tapering the nose to take an ER16 collet (making a matching 3/4in 16tpi chuck nut) while I'm at it. Thoughts?
headstock
depth 1.3in/ 33mm
spindle
