- Nov 14, 2016
- 3,289
I build models of trucks and fire apparatus, and that is what really led me here. Lots of things an be made on a lathe and mill that are not available as model parts.
One of the things I really want to make is wheels, in particular tiny replicas of the Firestone "widow maker" split rims widely used on commercial trucks from the 1950s through the early 1970s. I'm working in 1/25 scale so the complete wheel will be less than 1" in diameter.
I've been going around and around in my head trying to figure out how best to do that. I thought about splitting the rim to do the center part and then flip it to hollow out the back. Then form the rim section as one or two separate pieces. I think that would work but seems kind of tricky, takes lots of steps and would be easy to ruin the that center disc.
Then it hit me, instead of doing the center as a turned piece of brass or aluminum, what if I made a pair stamping dies? I could make a matching set shaped like the center disc, one convex and one concave. Then I would just need a disk of thin brass, put the two together and then schmoosh them together forming the center disk. I could drill the appropriate holes in the disk while flat, and even make a matching nipple in the dies that would go through the center hub hole to keep everything lined up.
It seems like this would solve many problems, the more time consuming machining of the dies would be a one time job (per size anyway). Once completed making additional center disks would be pretty quick, and best of all it would provide a relatively true to scale thickness. I'm thinking 0.02" brass which would be about 1/2" in scale vs what is probably closer to 1/4" in real life, but far closer to size than I think would be practical for me to reliably machine.
I would still have to make rims, but those seem like a fairly simple process (its a ring) and I could even cast those in resin once I do the first set.
Does this seem reasonable, if so any tips for stamping thin metal.
Should I use steel for the dies, or will aluminum be adequate?
Wack them with a hammer or should I be looking into a small hydraulic press?
