- Oct 27, 2013
- 124
Helping a buddy with his Peitenpol... (a model "A" Ford engine powered home built aircraft). He built the sheet metal cowl around the oil filler tube. The cap just rides below a rolled lip in the cowling. The tube has a 1.5" I.D. and a simple turned aluminum plug cap that is retained by a long cotter pin running through holes in the tube. The problem is the tube is too short and dosn't stick out of the cowl far enough. Now that the cowl is built, he realizes there's no way to access and remove the cotter pin... We cant really extend or make a new tube, because it will interfere with the straight exhaust pipe that is just above the filler port and all of the other work is now done.
He's asked me about putting in a threaded aluminum bushing and then turning down and threading the existing aluminum oil cap, Making it a screw on and off affair. Particularly, the existing cap has some nice engraving that says "Oil 5 Quarts" and he'd like to retain that and orient it so that when screwed down tight it's upright.
I'm worried about cap retention and/or bumming up the threads so I told him I'd try some new turnings first to see how well he likes them and how good we can make a fit. To stay within the 1.5" I.D. however, I'm thinking the new cap will be small and the oil service hole even smaller, maybe too narrow.
There must be a better way to cap a tube?
