Hello All;
This is the first time I have ever entered to any type of online forum, so please excuse me if I don't get this right the first try.
I have had this Tida lathe, TD-1236E (12x36) built in 1994 for awhile now.
When I first got it, I didn't have 220v available, so I wired for 110V.
It seemed a little under powered, and would not reverse.
I have since run 220v to it and wired it as the motor plate describes for "High Volt".
Still seems a little under power, but not too bad, I'm used to much larger machines so I can get used to taking light cuts.
My big issue now is trying to figure out how to wire the motor so I can spin in reverse using the lathes lever.
This motor is not original, it is a dual voltage 1.5hp farm motor.
Will it even do what I want?
Does anyone know what the original motor would have been?
I've tried a few different arrangements, trying to figure it out, and when I got a short and popped breaker, I thought I better stop before anything (or myself) get damaged
Nothing did thankfully.
Description of how it is now wired and what I have tried with pictures are on the attached word doc.
(I hope it opens)
Thanks in advance
Steve
(I hope it opens)
Thanks in advance
Steve
