- Oct 13, 2013
- 46
I have a millport 3hp varispeed bridgeport clone mill and it has a vibration when running that I think is coming from the cogs on the varispeed belt. It will also develop a squeal when cranking up the speed but immediately goes away when belt dressing is sprayed on the belt. The belt that is on it is a gates 2322V364 belt. The manual that I have shows a G-830 as the belt but I can't find any reference to that number anywhere on the net. I found a part number for a varispeed belt for a 3 hp bridgeport that is 875vc3830.
After doing some research I found there are three common belt angles some are 22 degrees, some are 28 degree, and some are 30 degree. The 2322V364 belt that is on it is a 22 degree belt and the 875vc3830 which apparently 3hp bridgeports use is a 30 degree belt which leaves me wondering if that is what should be on it.
Does anyone have a 3hp variable speed mill and if so what part number does your mill call for. I am not having any luck finding an exact part number for my mill.
