Need help, advice
Mike8623
Dec 18, 2013
607
Ok guys ametuer at machining here so dont laugh.
Using my bridgeport and the pictured r8 head with the type cutter pictured last i want to cut down ( bore) bout .700 with a width of .500 in a circle leaving the center portion exposed ( kinda like a moat around a castle). This will be be in a round piece of aluminum. My question is....is there a cutter made like the one pictured that has the carbide extending for the entire width of the cutter head versus just a portion of it?
Looks like a lathe job without a lathe...
Using boring bar backwards, cutting on inside, clever and doable.
Instead of using a boring bar, look for a end mill that will fit your head.
It will flex less, will not cut all the way across but it may give a better finish, straight flute needed.
Or, get a rotary table, rotate the part against a normal end mill in action.
Sent from my SM-G781V using Tapatalk
I do have a lathe and tried to cut it using a smaller version of .250 versus .500, there was too much tool chatter so i decided to move up to .500 wide.
I also have a rotary table and could use a .500 end mill.
I thought this other way would be easier and quicker if i could just find a round cutter that would cut the entire .500 diam.
I did find a cobra #37640 cutter but they want 60+ bucks for it. I was hoping to find another cutter more reasonable. I guess as a last resort i'll use rotary table with end mill. You'd think there would be a cheaper cutter
I think i may have found one i can afford. Thanks for taking time to respond, i do appreciate it
Since you have a rotary table, that is the best tool for the job.
